2001 Toyota Sequoia, Security with Keyless Entry
pushrodv8
Member - Posts: 12
Posted: July 23, 2002 at 3:21 PM / IP Logged
Recently worked on a 2001 Toyota Sequoia installing security with keyless entry.  Vehicle had 5 separate door trigger wires and I tried to use diodes as recommended, but could not figure why I could not get them to work.  I tested each tigger with a mulitmeter.  I first tried installing the diodes with the bands facing the doorpins and the alarm could not see the doors.  So I reversed them and the alarm thought that the doors were always open, even with them closed.  AM MISSING SOMETHING HERE, I mean diodes are not terribly complicated to figure out!?!   Any help would be great and many thanks in advance.
Platinum - Posts: 12,488
Posted: July 23, 2002 at 9:11 PM / IP Logged
Are you using the right door trigger wire on the alarm ? Most systems come with a + and a - trigger wire to attach to the vehicle.
pushrodv8
Member - Posts: 12
Posted: July 25, 2002 at 6:12 PM / IP Logged
Using negative door input on a DEI system.
Posted: July 25, 2002 at 9:17 PM / IP Logged
Did you hook up likethis : https://www.the12volt.com/diodes/diodes.asp
