2004 dodge ram window help
mobiletoys2002
Gold - Posts: 1,050
Posted: November 23, 2003 at 6:00 PM / IP Logged
Do i have to go into the driver door for window control? i am tring to do the driver and passenger window,i am using a 530 t.Can i get the wires inside instead of going into the door?
vaderfop
Copper - Posts: 95
Posted: November 23, 2003 at 6:37 PM / IP Logged
For the Driver window you will probaly have to go into he door. For the passenger window you could probaly find the wires in the driver kick panel, butsince you would have to go into the door for the driver side i would just install the intire unit in the door. That way you only have to run ground when armed, power, ground ( i would run it to a frame of the car, instead of ground in the door, that way you will get a better ground), and the channel output (which ever channel you want to hook it up to, mine is on channel four...) into the car. IMO run 4 wires through the door should not be that bad.
Hope this helps.
Remember check all your wires with a DMM!
mobiletoys2002
Gold - Posts: 1,050
Posted: November 24, 2003 at 8:25 PM / IP Logged
well i think this car has a one touch window down on the passengerswitch side so do i have to go into both doors??
gtchida
Copper - Posts: 89
Posted: November 24, 2003 at 9:51 PM / IP Logged
mobiletoys,
you should be able to catch the pass side at drivers kick panel
securinu
Silver - Posts: 772
Posted: November 24, 2003 at 10:50 PM / IP Logged
Keep in mind if you get the wires in the driver kick only the driver switch will have one touch up and down.
Joe O'Byrne
Owner / Installer
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
