Want to disable/bypass 1988 towncar Alarm
srraynor
Posted: December 09, 2003 at 9:13 AM / IP Logged
My son's '88 Towncar is having alarm problems and has stranded him once (he's 17). The car is not worth putting money into (180+k miles). In fact, you would have to pay someone to take it. It's pretty much safe. But it gets him from point A to B safely.
To solve his problem, We want to bypass the factory Alarm System altogether.
 Is there an easy way to do this?
shaggy12volt
Copper - Posts: 164
Posted: December 10, 2003 at 9:03 PM / IP Logged
My wiring info on system doesn’t show the there is a factory alarm but there could be.
You can bypass the starter kill if it has one by getting some 12 or 10 gage wire.
Start at the ignition harness in the steering column.
 Cut the WHITE/ pink wire about 3inchs from the key cylinder solder the wire to it and run the wire thru the firewall.
 (if you cant find a rubber seal to poke thru you may need to drill about a 1/4" hole to run the wire thru)
run the wire to the starter solenoid disconnect the factory wire ( should be WHITE/ pink  but if not it is the small wire out of the 3 that are there I believe )
hope this helps.
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
auex
Platinum - Posts: 5,041
Posted: December 10, 2003 at 10:11 PM / IP Logged
Actually, I doubt it is factory, look under the dash for the alarm module and pull the fuse out(probably the one on the red wire, this depends on the brand of alarm). Then find the starter kill relay and just hook the starter wire back together. I personally would not re-run the starter wire to the soleinoid.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
