AutoPage 850LCD
Lsidonis
Posted: December 12, 2003 at 9:18 PM / IP Logged
The H8/8 Pink Wire is a programable output for either 2 stage unlock OR OEM disarm. I need both. Any way around this?
Thanks.
HamiltonAudio
Silver - Posts: 278
Posted: December 14, 2003 at 1:33 PM / IP Logged
you want the 2 stage unlock AND a disarm signal?  try using the first unlock pulse wire (they will be separate) and split it with diodes to disarm the alarm.  Hence, on the first unlock, the system pulses negative to unlock and disarm at the same time...
b
Lsidonis
Posted: December 15, 2003 at 9:42 AM / IP Logged
Thanks for the info. But I also need the disarm for remote start.
jrilla
Gold - Posts: 1,498
Posted: December 15, 2003 at 10:32 AM / IP Logged
Isnt that stupid? I thought they would have changed that from the 750, but I guess not.
What vehicle? There may be another way to disarm for remote start. There may be an easier way once i know what vehicle, but you could use a constant to momentary relay setup using a cap and a resistor as shown in the relays section.
J Rilla
Owner/Installer
