Clifford RS3 Problems
mmdb
Member - Posts: 6
Posted: December 19, 2003 at 5:16 AM / IP Logged
Recently the transmitter stopped confirming signals from the brain. Also there's some minor problems with a false signal, when arming the alarm a shock sensor on the transmitter would beep. I read previous posts which searching that the RS3 had problems so hence the new RS3.5 was now out. Is there a way to get a newer version of it? I bought my alarm off of ebay and installed it myself. Is it even worth bothering for an upgrade? Thanx
JWorm
Platinum - Posts: 2,208
Posted: December 19, 2003 at 8:00 AM / IP Logged
Buy the new style remote from the RS3.5
It will work fine with the RS3
mmdb
Member - Posts: 6
Posted: December 19, 2003 at 4:38 PM / IP Logged
ok so the new remote should fix everything?
profuse007
Gold - Posts: 2,015
Posted: December 19, 2003 at 10:16 PM / IP Logged
i dont think the new remote would fix everything, the signal generated by the unit side not the remote side.
Houston,TX
JWorm
Posted: December 19, 2003 at 11:07 PM / IP Logged
The first generation 478 series remotes suck. They go bad all the time and exhibit the problems being seen here. If he gets a new one everything should work fine. There is a small chance something else could be the problem though. I've heard of the antenna or cable needing to be replaced, but those problems are rare compared to the remote freaking out.
mmdb
Member - Posts: 6
Posted: December 20, 2003 at 2:19 AM / IP Logged
K thanx for the advice. I'll get that remote and see if it does good.
Monday, July 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
