Posted: December 28, 2003 at 6:22 PM / IP Logged
Posted: December 28, 2003 at 7:07 PM / IP Logged
Posted: December 28, 2003 at 7:45 PM / IP Logged
Wednesday, January 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
By the way, another option would be to get a key make sure it is programmed to the vehicle and will start and run it, then just cut the key apart or grind it down and have them put the head of the key in the box. This way nobody can take that key and use it in the ignition. I've never needed to put the key in the dash on a ford/lincoln/mercury so there is definately other options available. Good luck,
Mike
