ultrastart as2250 in 2000 silverado
plunatic
Posted: December 30, 2003 at 2:53 PM / IP Logged
I have just installed an ultrastart as2250 in a 2000 silverado.  Everything is working except keyless.  I am getting nothing from my lock unlock wires. I just wanted someone to talk me through where the lock unlock wires should go just to make sure I did it right.
draasch
Gold - Posts: 2,172
Posted: December 30, 2003 at 5:03 PM / IP Logged
Power Lock L BLUE HIGH IN DRIVERS #203
Power Unlock WHITE KICK PANEL #202
#202 - See Positive Pulse Door Lock Diagram. (2 Door w/Keyless or 4 Door) #203 - See Reversal Rest At Ground Door Lock Diagram. (2 Door w/o Keyless)
what is the output on the alarm??????
i think they are neg.....look at the info above and see which one applies to you....drop a line back if you cant work it out..................
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
plunatic
Posted: December 31, 2003 at 7:30 AM / IP Logged
yes the outputs are neg.
boomer_106
Silver - Posts: 710
Posted: December 31, 2003 at 12:20 PM / IP Logged
Then you'll need to reverse the polarity with a relay. You didnt mention if it had factory keyless or not. If not you will have to do the reversal rest at ground wiring. I think there is a diagram here showing that.
https://www.the12volt.com/doorlocks/doorlocks.asp
