04 dodge ram door locks
vetteluvr33
Member - Posts: 22
Posted: December 30, 2003 at 7:27 PM / IP Logged
hey guys, i am installing a command start in a 04 ram, the wire is a purple with a dark green stripe, i have located it, and i have put the resistors in line with the rs to trigger the locks. my problem is if i hook up both the unlock and lock to the prpl/grn wire then none of the locks work, but if i hook up just one or the other, they work fine, now i have tried cutting the wire in half but then nothing works, if i use relays to trigger them, will this fix my problem, any help would be great. oh yeah, the rs i am using sends a negative pulse for the locks if that helps any.
  thanks k
serialthrlla
Copper - Posts: 57
Posted: December 30, 2003 at 7:56 PM / IP Logged
you'll need relays.After you put the resistor in the lockwires from the remote start, your signal will not be strong enough for the locks to function properly
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
