Clifford Smart Remote Start 3 locks
fordtech
Posted: January 06, 2004 at 2:56 PM / IP Logged
I'm installing a Central locking system in my car, and it uses a neg trigger single wire (purple to lock, blue to unlock or vice versa)
I'm not sure how to wire that up with the NC NO COM unlock....NC NO COM lock from the remote start.
any help would be greatly appreciated!
Brad
draasch
Gold - Posts: 2,172
Posted: January 06, 2004 at 3:55 PM / IP Logged
what is the model number of the unit????
what is the brand of door locks????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
fordtech
Posted: January 06, 2004 at 6:00 PM / IP Logged
I'm not sure what the model number is on the system, and the locks are from A1 electronics Mesa central locking system.
sparkie
Platinum - Posts: 2,061
Posted: January 06, 2004 at 6:59 PM / IP Logged
If your system requires a ground pulse to lock and unlock wire your starter as such:
Lock common - ground; Lock normally open - Lock wire for power lock system. Normally closed - not used
Unlock common - ground; Unlock normally open - Unlock wire for power lock system; Unlock normally closed - not used.
sparky
fordtech
Posted: January 06, 2004 at 11:29 PM / IP Logged
I figured it out.  On the Smart Remote Start III I had an OEM disarm and OEM arm wire, (BLACK/ green and BLACK/ orange)  Those are a pluse ground, which is what I needed.  I have also figured out the NC, NO, COM wiring as well, if anyone needs info.
Thanks for everyones help!!
Brad
