2002 dodge neon remote start install
bhouse1587
Posted: January 13, 2004 at 10:37 PM / IP Logged
i have installed all wires with the bypass kit (it is the grey key) and it just clicks it wont start and i dont know why i have installed starters before and didnt have a problem could someone help me they both are bulldog security (starter, and bypass kit) could it be a bad starter or bypass please give help. and what is this i hear about the resistor to unlock the doors im confused with that thanks guys...
Tim
tjdurham
Copper - Posts: 180
Posted: January 13, 2004 at 11:14 PM / IP Logged
you will need resistors to do door locks and factory disarm try putting a key in the ignition not turning it on  and see if it starts if it does check your bypass not familliar with bulldog havent installed them since 95 (lost alot of $$$on them)
tj
bhouse1587
Posted: January 13, 2004 at 11:20 PM / IP Logged
ive done that it just doesnt want to start. i havnt put the door locks in because it really confused me but i think i might take both back and get new ones (just the modules) becaues i installed this same one on my car and i didnt have a problem at all. so i think it might be the modules are bad but any other suggestions? i cant get it to work.. thanks
bhouse1587
Posted: January 14, 2004 at 11:18 PM / IP Logged
does anyone have any other suggestions???
Alpine Guy
Platinum - Posts: 2,478
Posted: January 15, 2004 at 8:17 PM / IP Logged
if it has a factory alarm, that may be whats stopping it from starting. You will need to hook up the disarm wire.
tomberndt
Member - Posts: 8
Posted: January 15, 2004 at 11:11 PM / IP Logged
check your tach signal, or are you RS by voltage type?  Factory disarm shouldn't  be making the vehicle not start.
Platinum - Posts: 12,488
Posted: January 15, 2004 at 11:16 PM / IP Logged
Did you use a starter disable relay in your installation ? If so make sure that the starter wire from the remote start unit is attached on the MOTOR side of the relay and not on the SWITCH side.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
