help mounting alarm brain behind stereo?
revmatt99
Member - Posts: 28
Posted: January 19, 2004 at 3:18 PM / IP Logged
I am going to be installing a crime guard 533i3 alarm in my 2001 chevy silverado extended cab truck. i was wanting to mount the alarm brain behind the stereo. silly question but how do you remove the stereo? it is just the factory stereo and is there any other locations that would be better suited to mount the alarm brain at? thanks for the help have a good day:)
abright52
Copper - Posts: 137
Posted: January 19, 2004 at 5:14 PM / IP Logged
I doubt that there is enough room behind the radio, GM likes to squeeze those in pretty tight. Anywhere under the dash should work, just use zip ties and keep the wiring and module away from anywhere that need to move to operate (IE: Steering Column).
If you still want to check out the radio, here are the instructions for a 2000:
2000 Silverado Radio Install
auex
Platinum - Posts: 5,041
Posted: January 19, 2004 at 5:19 PM / IP Logged
All you have to do to remove the radio is pull the large instrament/radio bezel off, it just pulls no screws or anything. Then with that off just look at the radio, on the side are to plastic tabs, push these down and pull the radio out. I would however recommend that you come up with another spot, the first place a thieve is going for is going to be the radio. If this happens then he not only has your radio he will have your alarm as well.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Teamrf
Gold - Posts: 1,031
Posted: January 19, 2004 at 9:42 PM / IP Logged
If you really want to hide your alarm brain from a potential thief just mount it under the seat or something...but if he is a good thief he will have what he wants from your truck.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
daniel2002p
Silver - Posts: 524
Posted: January 20, 2004 at 6:13 AM / IP Logged
if you take out the dach trim bezzel, be VERY CAREFULL not to brake the hazzard swith, as those brake like nothing.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
sroth140
Silver - Posts: 513
Posted: January 20, 2004 at 4:05 PM / IP Logged
i think those hazard buttons (at least on the s-10) cost like $110+ at a dealership.  supposedly, if we break one at my install bay, youre fired.  on the s-10 97 style we have to drop the colum.
anyway, i think one of my installer buddies back home mounted his brain not only behind the radio, but all the way back almost under the base of the windshield.  possibly a little towadrs the left.  why not go behind the glove box?
