Install Questions
anker
Posted: January 28, 2004 at 9:27 PM / IP Logged
I'm installing an Astrostart 2100 in a 2003 GMC Sierra.  The unit has one Accessory output and one Innition output, but the truck has two wores for each.  Do I hook the one wire from the unit to both wores under the dash?
jrilla
Gold - Posts: 1,498
Posted: January 28, 2004 at 10:43 PM / IP Logged
No, use a relay for the 2nd Acc and 2nd Ignition. There should be a programmable relay on board you can use for the 2nd Ignition.
J Rilla
Owner/Installer
