Cherokee Parklights
mark2003
Member - Posts: 33
Posted: February 01, 2004 at 4:37 PM / IP Logged
99 Grand Cherokee.... Best way to hook-up parklights for a remote starter!!!
NINsane18
Copper - Posts: 103
Posted: February 01, 2004 at 5:20 PM / IP Logged
Here is some info from a previous post:
Jeep Grand Cherokee 1999+
Parking Lights
In the past the only option to illuminate the parking lights of the Jeep Grand Cherokee was to supply a ground pulse through a 240 ohm resistor to the parking light wire at the headlight switch. While this will still work, we believe this Installation Note will provide a safe and easy alternative which requires no hard-to-find parts.
1) Locate the Parking Light Relay and unplug it.
2) Remove terminal 87A and attach a wire to terminal 30. (See diagram.)
3) Re-Install the relay leaving the wire attached to terminal 30.
4) Connect the wire (From terminal 30) to the AutoCommand Lights Wire (Yellow, see AutoCommand Instructions.)
Tim-May!
mxxmikexx
Silver - Posts: 796
Posted: February 01, 2004 at 5:40 PM / IP Logged
another way is to just grab the negative trigger hazard light wire in the harness coming from the steering wheel. this works fine aswell, you just cant have the parking lights stay on constantly because if that wire sees a constant ground the lights will flash obviously (hazards)
I've done this many times, works fine
just my 2 cents.
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Teamrf
Gold - Posts: 1,031
Posted: February 02, 2004 at 2:03 PM / IP Logged
Mxxmikexx, that is a good idea. I've never thought about using the hazards for parking lights when I've ran into a problem for the parking lights..Learned something new today.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
