2002 Avalanche alarm install ?s
MrFleming007
Member - Posts: 10
Posted: February 01, 2004 at 10:59 PM / IP Logged
Hi everyone. I'm installing a Prestige APS996a alarm into my '02 Avalanche, and had a couple of questions. Along with the interior lights and puddle lamps on the outside coming on unlock, I would also like the daytime running lights and reverse lights to come on too. (Never can have too much light at night to see what your about to step in). I was wondering if anybody knew where the easiest location to tie into these wires would be, what color the wires are, and to turn them on, if I would need a +12 volt current, or a ground. Thanks for your help in advance!
-Owen
bmf1000d
Silver - Posts: 345
Posted: February 01, 2004 at 11:25 PM / IP Logged
If you hook up the parklights as normal then the daytime running lights should come on as well. As for the back up lights you would have to tap into the back up light wire i dont have that wire color here but i do have the rest for you
AVALANCHE          2002-2004
WIRE COLORSLOCATION
12 VOLTS CONSTANTRED & RED / WHITEIGNITION HARNESS
IGNITION 1PINK (16 AWG)IGNITION HARNESS
IGNITION 2WHITE (18 AWG)IGNITION HARNESS
ACCESSORY /HEATER BLOWER 1ORANGEIGNITION HARNESS
ACCESSORY /HEATER BLOWER 2BROWNIGNITION HARNESS
STARTERYELLOW (18 AWG)IGNITION HARNESS
PARKING LIGHTS ( +)BROWNDRIVER KICK PANEL
DOMELIGHT *SEE NOTES * 1
POWER DOOR LOCK *3
POWER DOOR UNLOCK  *SEE DIAGRAM*
TACH SENSORNOT PINKANY FUEL INJECTOR
BRAKEWHITE ( + )AT THE BRAKE PEDAL SWITCH
HORNBLACK / YELLOW OR BLACK ( - )AT THE STEERING COLUMN OR GRAY PLUG AT THE BCM  *2
FACTORY DISARMLT. GREEN ( - )DRIVER DOOR MODULE IN DOOR
FACTORY ANTI-THEFTTYPEPASSLOCK 2
NOTES:
*1 - The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black and the RR is lt. GREEN/ black, they are in a harness in front of the fuse box leading to the BCM rear plug. Use all four wires and diode isolate each.
*2 - The BCM (Body Control Module) is under the driver side dash.
*3 -  At the BCM in the purple plug, look at row B, cavity two and three should be open with not wires in then. If you make connectors for these pins you can connect them as a( TYPE B ) door locking system.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
MrFleming007
Member - Posts: 10
Posted: February 02, 2004 at 12:03 PM / IP Logged
Thanks! Alarm and remote start are in and working great... still need to hook up the illuminated entry. Probably next weekend. One more question though- on these trucks there is a 30 delayed lighting after you leave the vehicle. When the courtesy lights go off, the alarm gives off a warning chirp. Anybody have any thoughts on how to get the alarm to stop doing this (while still leaving the delayed lighting on)?
MrFleming007
Member - Posts: 10
Posted: February 02, 2004 at 12:06 PM / IP Logged
30 second delayed lighting I mean....
Fred Anthony
Member - Posts: 28
Posted: February 02, 2004 at 12:53 PM / IP Logged
Well you have to tap into the domelight super vison wire, see his table above, below in the notes
Quote: *1 - The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black and the RR is lt. GREEN/ black, they are in a harness in front of the fuse box leading to the BCM rear plug. Use all four wires and diode isolate each.
When you connect your domelight supervision output wire from the alarm to the wires above it will keep the domelight and entry lights on for 30 seconds.
Fred.
Fred Anthony
Member - Posts: 28
Posted: February 02, 2004 at 12:56 PM / IP Logged
Did you hook up your door triggers to the delayed lighting wires? If so it may do that..I think you can tap right into the wire comming from the door switches themselves, you will have to do the driver and pass. seperate and diode isolate each. I had to do this on an eclipse.
Fred.
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
