need help with Hornet 554t problem
hadehatch
Posted: February 06, 2004 at 3:02 PM / IP Logged
hey guys, ive been reading this fourm for a while and picked up a lot of great information.. today i installed a hornet 554t in my 92 civic, no remote start. everything works except the pager is acting strange. when i put in the battery it shows the speaker and unlock icons all the time.. even when i arm the car.. plus i get no feedback from the car to the pager.. all the buttons work along with their respective features though.. any ideas? any help would be appreciated.. thanks
-Cosmin
hadehatch
Posted: February 06, 2004 at 9:48 PM / IP Logged
still didnt figure this out, called a few installers and they tried to sell me a new remote for around $75.00.. if there is another way to fix this please let me know.. if not.. is there any place i can get these remotes for less? thanks in advance.
hadehatch
Posted: February 09, 2004 at 1:11 PM / IP Logged
still waiting on a suggestion.. if you can help i would appreciate it.. thanks
Platinum - Posts: 12,488
Posted: February 09, 2004 at 1:18 PM / IP Logged
If you purchased this from a dealer, they should be able to get you a replacement remote for free as part of warranty. The first thing I would try is to remove the fuse from the CPU and the battery from the remote control and try to reprogram the remote once again. If problem persists, then get a new remote through warranty.
hadehatch
Posted: February 10, 2004 at 11:53 PM / IP Logged
ok if the alarm was sitting outside a car for a while (no power) and i recently installed it would i haev to program the remote?? it performed the basic functions as soon as i powered it up... let me know
thanks
Posted: February 11, 2004 at 2:54 PM / IP Logged
Not sure with DEI remote's and CPU's. Some units loose any memory of the remote's after a certain amount of time while other's retain all remote's in their memory forever until you reprogram more remote's into it's memory. Nonetheless, I would still go back to the dealer and get them to take a look at the remote control and the way it's functioning.
x6369x
Copper - Posts: 108
Posted: February 13, 2004 at 11:54 AM / IP Logged
Try re-programming the remote. Of all of the DEI alarms that I've done that were brand-new in the box, they all came programmed. Where'd you get the alarm? Maybe they had to "borrow" the remote for another customer, and threw in a replacement when they got another remote in stock.
Friends Don't Let Friends Bump Stock.
hadehatch
Posted: February 13, 2004 at 7:07 PM / IP Logged
well i got the alarm from a friend after he junked his car.. he had it installed at a shop.. i installed it in my car.. the warrenty probably wouldnt cover it anymore... ill have them check it out after i put the engine in my car.. thanks for the replies!!!
mecpcert_1
Copper - Posts: 83
Posted: February 15, 2004 at 2:28 AM / IP Logged
try unplugging the brain, the antenna(make sure it is not torn or ripped) and take out the battery to the remote.
plug the brain and antenna back in, put the battery back in the remote AND within the "little musical that plays", hit the lock button.
 if this does not work, time for a new system.
       good luck and have fun!!!!
do it right the first time....less warranty work=more money!:)
