DEI 515r Siren with backup battery
hongkongrr
Posted: February 07, 2004 at 8:52 PM / IP Logged
Hi,
I searched the whole forum but couldn't really find the ans to my question. I was planning on buying DEI 515R which has 4 outputs (pos/neg power and pos/neg trigger). I was going to install the siren to my car w/o using either of the trigger wires because I just care for it to go off when the power gets pulled. Does the siren work like this?
Thanks!DEI 515r Siren with backup battery -- posted image.
Teamrf
Gold - Posts: 1,031
Posted: February 08, 2004 at 2:48 AM / IP Logged
The DEI backup battery I had was an actual siren and it went off with the alarm as well.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
hongkongrr
Posted: February 09, 2004 at 12:34 PM / IP Logged
That is not really my question. I don't want to hook up the triggers to my alarm. I just want it to go off when the bettery is connected. Does that work?
hongkongrr
Posted: February 09, 2004 at 12:35 PM / IP Logged
hongkongrr wrote:
I just want it to go off when the bettery is <b>connected</b>.
I mean disconnected
daniel2002p
Silver - Posts: 524
Posted: February 09, 2004 at 12:54 PM / IP Logged
the way those work is they go off when the alarm brian looses power.  the instant trigger on the alarm becomes ground when the power is cut, and the the backup sees ground is goes off.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
hongkongrr
Posted: February 09, 2004 at 3:14 PM / IP Logged
Is there any way to hook it up without an alarm brain?
daniel2002p
Silver - Posts: 524
Posted: February 09, 2004 at 5:15 PM / IP Logged
it gets very comlicated, unless you are very comfortable with car security i suggest you do not attempt.  you have to set up two relays that when one looses 12v (when they take off the pos side of batt) that it show continuity to ground to the back up battery, and the same with neg side of the battery.
    1.8L VVT-i I-4
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
