95 Toyota Previa light flash
befranklin
Posted: February 17, 2004 at 4:22 PM / IP Logged
I am current newby installing a DEI Diablo2 alarm and have found all the wires except one the parking light flash. Do you know if the parking light wire from the switch is a negative output? I tested it with a DMM but didn't get any readings. I guess if it was negative output I shouldn't see any readings. I would like to jus ground the wire from the switch and they should turn on or indicate closed circuit if I use Ohm on my DMM but don't want to short anything out. I believe the wire at from the switch is white to the connector and is Green-Black after. Should I use a relay if it is?
I should mention that the alarm has a positive and negative out-put
Bernie95 Toyota Previa light flash -- posted image.
kgerry
Platinum - Posts: 3,455
Posted: February 17, 2004 at 5:30 PM / IP Logged
parking light wire should be green in the DKP and it's positive
befranklin
Posted: February 17, 2004 at 9:50 PM / IP Logged
Nope,
Its in the seat belt relay box green-red wire and it's negative it also can be wired from the switch, now if I could only figure out the door trigger wire I'd have this thing licked but I haven't figured out which wire it is and where it at.
Bernie Franklin
