Radio by auxillary channel of remote
N0tjustsomeguy
Posted: February 18, 2004 at 10:09 AM / IP Logged
I want to be able to turn on my stereo by pressing one of my auxillary buttons for my alarm.  I have a Matrix I installed and have one accessory wire available (Channel 3).  This is sending a - 200mA signal when the button is pressed.  Can I hook this wire to a relay to be able to feed power to the stereo even if the key isn't in the ignition?
tcool
Copper - Posts: 100
Posted: February 18, 2004 at 10:18 AM / IP Logged
Check out the section on Relays on this site. Great references for all kinds of applications, including pulse to latch.
https://www.the12volt.com/relays/page5.asp#pts
bzzzzttttt
bmf1000d
Silver - Posts: 345
Posted: February 18, 2004 at 1:26 PM / IP Logged
Yes you an just hook up the relay as shown in the diagram and you should be fine.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
