Clifford RSX 3.5, 1999 Dodge Durango
jacook81
Posted: February 24, 2004 at 11:56 AM / IP Logged
i'm installing a clifford RSX 3.5 into a 1999 Dodge durango, the problem i'm having is with the ignition and acc. connections.  The wiring diagram I have says:
IGN   DK Blue
IGN2 Blk/org
ACC  BLk/org
this is from the12volt.com
I also found this:
ign   DK Blue
Acc  Blk/Org
acc2 Blk/whit
However, in the harness of about 25 wires, none are just dk/blu.  When I put a meter on all the pins, i find a blk/whi that appears to be ign, and a brwn/green  that appears to be an acc.
but they are all small wires.  Usually they are bigger, ie) Ford/GM
What wires should I use??
Thanks!
JMaxx93
Copper - Posts: 73
Posted: February 24, 2004 at 12:22 PM / IP Logged
techsoft states your latter listing as correct.  what i would do is find the key switch and look in relation to that under the dash.  i can't remember exactly what a durango looks like but i don't remember there being anything special about it.
