Tach wire or voltage wire ?
daba58
Member - Posts: 6
Posted: February 26, 2004 at 11:21 AM / IP Logged
 What's the best place for you RS to hook up to on a 2002 GMC Serria. The alarm is a autopage 850lcd. Having problems tracking down the tach wire.
tjdurham
Copper - Posts: 180
Posted: February 26, 2004 at 12:21 PM / IP Logged
go to any coil pack under hood and there are 4 wires 3 of them are the same on all of the packs the odd color is your tach use any of themand youll be ok
tj
daba58
Member - Posts: 6
Posted: February 26, 2004 at 12:42 PM / IP Logged
Well I found a tach wire and it's ok but not the truck turns over and dies. I have a DEI 555L and it's wired up right I think. Anything on my autopage alarm that would cause it not to fully crank over??????
chris
draasch
Gold - Posts: 2,172
Posted: February 26, 2004 at 12:55 PM / IP Logged
put a key in the ign. and try to start it again....if it stays running, then you dont have the bypass working right.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
daniel2002p
Silver - Posts: 524
Posted: February 26, 2004 at 8:05 PM / IP Logged
on the 555l make sure that the passlock ground is hooked up in the right place.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
