2003 Dodge PU remote start
ramit Damnit
Member - Posts: 16
Posted: February 26, 2004 at 1:56 PM / IP Logged
I have looked at different diagrams for my 03 dodge by searching related topics....and they all seem to be different....im installing a remote starter (crimestopper 2011 RS) and so far i have seen about 3 different versions of the ignition wires....i need some relay help on how to wire....not to good with relays...i havent found anything for ignition wires in the RELAY section either!..i think the dodge quad cab is different wiring then the single cab....
heres what i have to wire...
Ign#1- blue wire, ign#2- red or RED / white wire, ign#3- dark green, ign#4- orange....how do i wire all of these wires if i only have 2 ignition out puts??....tie 2 wires together into 2 relays?? BTW...on the alarm system there is a pink wire for ignition #1 and a pink/white for ign #2....im guessin that i have to use only the pink/white wire to wire ignitions #2-4 ?? ANY HELP APPRECIATED!!
draasch
Gold - Posts: 2,172
Posted: February 26, 2004 at 3:09 PM / IP Logged
Make:   Dodge
Model: Pickup - Fullsize
Year:    2003
This Database Was Last Updated On:    6/9/2003
Index #: 49
Alarm
Constant 12 volts PINK/BLACK RED / WHTITE IGNITION SWITCH HARNESS
Ignition 12 volts BLUE 16 gauge IGNITION SWITCH HARNESS *
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light BROWN (-) DRIVER A PILLAR (TECH NOTE)
Trunk Pin Switch
Parking Lamp BLACK / YELLOW (+) AT RELAY BOX UNDER HOOD **
Power Lock WHITE/ DARK GREEN 14 PIN CONNECTOR IN DRIVER #217
Power Unlock SINGLE WIRE SYSTEM KICK PANEL ***
* USE THE SMALL GAGE BLUE WIRE! ** BLACK / YELLOW (+) At Relay Box Under Hood Or At Parking Light. *** WHITE/ DARK GRN Wire Must See Ground Through 820 Ohm Resistor For Lock And Ground Through 330 Ohm Resistor For Unlock.Alt: 220 Ohms. Confermed By More Than One Source The 220 Ohm Worked On Unlock. #217 See Single Wire Resistor Door Lock Circuit Diagram
Accessories
Window Up D\ LT BLU P\ BRN/WHT D\ BLU/WHT P\ GRY/WHT @ DRIVER DOOR
Window Down F/ WHITE F/ VLT/WHT R/ RED / BLK R/ GRN/WHT MODULE #212
Ign Key Warn BLACK/ DK GRN (-) IGNITION HARNESS
Trunk Release
OEM Horn BLACK/ RED (-) STEERING COLUMN HARNESS
Headlights PURPLE / YELLOW (-) SEE TECH NOTES
OEM Alarm Arm LT GRN/ORANGE DRIVER KICK PANEL *
OEM Alarm Disarm SINGLE WIRE SYSTEM
*LT GRN/ORANGE-Arm/Disarm Must See A Ground Pulse thru a 1.5K Ohm Resistor To Arm/Lock and a Ground Thru A 550 Ohm Resistor To Disarm/Unlock Use Double Pulse Unlock. (Installer has Reported 249 Ohm Resistor For Disarm) #212-See Reversal Rest At Positive Power Window Circuit Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
ramit Damnit
Member - Posts: 16
Posted: February 26, 2004 at 5:56 PM / IP Logged
OK THIS DODGE IGNITION WIRE IS CONFUSING!!...SOME DIAGRAMS SAY I NEED TO HOOK UP THE RED & RED / WHITE FOR IGN #2 AND BLUE FOR IGN#1....AND SOME SAY ALSO HAVE IGN#3&4 WHICH ARE DARK GREEN AND ORANGE....HOW MANY IGNITION WIRES HAVE TO BE HOOKED UP FOR SURE ON A :
2003 DODGE RAM 1500 QUAD CAB???...HAS ANYONE INSTALLED A CRIMESTOPPER 2011 R/S RECENTLY ON THIS??...MY RUNNING LIGHTS,ALARM,DOOR LOCKS WORK FINE!!...I CANT GET THE IGNTION SIRES RIGHT TO GET IT REMOTELY STARTED....OR IS THERE A WEBSITE WERE I CAN GET THIS INFORMATION FOR CERTAIN?!?!
ramit Damnit
Member - Posts: 16
Posted: February 26, 2004 at 6:01 PM / IP Logged
lemme clarify what it does.....all power comes on when i hit start....(dash and gauge cluster, a/c, radio) but after the 6 seconds it clicks and nothing. doesnt even try and turn over. any help would be appreciated
daniel2002p
Silver - Posts: 524
Posted: February 26, 2004 at 7:57 PM / IP Logged
the most sure way is to get a DMM and test yourself, cannot go wrong there.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
JWorm
Platinum - Posts: 2,208
Posted: February 26, 2004 at 8:11 PM / IP Logged
I like working on these trucks. Pretty easy to work on, once you know what you are doing.
There are 2 ignitions and 2 accessories that need to be powered up.
Ignition 1 - blue
Ignition 2 - red or RED / white. There are a bunch of red wires, and I think 1, possibly 2 RED / white wires. You need to find the one that tests as an ignition. It will show power when the key is in the run and crank positions only. Some of the red and RED / white wires will be constant wires, don't confuse this wire with those
Acc 1 - green
Acc 2 - orange
When the 2002 Ram (same wiring) came out, some wiring charts were showing to hook up 4 accessory wires. BLACK/ white and another color I forget. After a while, people realized that two of those weren't needed for the truck to run properly because they were for the radio, wipers and others things you don't need on when warming up the truck.
You will need to add a relay for the 2nd acc. wire. Wire it as follows:
86 - to accessory 1
85 - "ground when running" output from remote start. Also called "3rd ignition trigger" on some systems
87 - fused constant +12v
30 - to 2nd accessory wire.
There are many ways to wire the above relay, but this way works just fine.
The fact that your truck won't crank probably doesn't have to do with you missing an ignition or accessory wire. Does your truck have a grey key or black key? If its grey, you have an engine immobilizer. Put the key in the key cylinder in the off position and try to remote start it and see what happens. Try doing a search for "555C" or "Sentry key"
ramit Damnit
Member - Posts: 16
Posted: February 26, 2004 at 9:53 PM / IP Logged
thanks for the replies....i have tested the red wire and the RED / white wire that im using..and they both have power only when key is in "on" position and started..only problem is ....when i use the RED wire by itself the dash will NOT power up, but if i leave the key in the on position it will start...and when i hook up the RED / white wire it will power up the dash...but not start....so how can i not use both of them...are they the wrong wires...BTW MY KEY IS BLACK AND I DO NOT HAVE FACTORY KEYLESS
daniel2002p
Silver - Posts: 524
Posted: February 27, 2004 at 6:21 AM / IP Logged
you also have to power up your acc wire, it is balck/orange, that wire powers your dash, radio, and also I believe the wipers.
    1.8L VVT-i I-4
ramit Damnit
Member - Posts: 16
Posted: February 27, 2004 at 4:32 PM / IP Logged
FINALLY I GOT MY TRUCK TO START!!!! ONLY PROBLEMS IS I CANT SEEM TO FIND THE GREEN& ORANGE ACC. WIRE...THE GREEN & ORANGE I FOUND ARE NOT POWERED WHEN THE IGN IS TURNED TO THE ON AN OFF...ARE THESE WIRES BIG OR SMALL??....ALSO IM THROWING CODES ON MY DASH WHEN IT IS REMOTELY STARTED....COULD THIS BE FROM NOT HAVING THE SECOND ACC WIRE HOOKED UP??
ramit Damnit
Member - Posts: 16
Posted: February 27, 2004 at 5:24 PM / IP Logged
Okay ...after reading many post on dodges i have read that the ign# 2 and #3 wires have to be hooked up along with the acc#1&2 (green & orange) well there are many diagrams with different ign wires and acc wires...mainly the 2nd igns and accs. i have tested THE ONLY orange wire that is running down my steering column to the ignition harness and it does NOT test positive wheter ign is on or off or cranked!!...the BLACK/ white wire is for the radio, although when i power it...the radio does not come on!, some diagrams say that the 3rd and 4th ignition are the green and orange..!?!?!....now i know there is someone with an 2003 dodge ram 1500 SLT 4.7L V8 with the correct wiring diagram for acc. and igntion.....MY MAIN PROBLEM IS THAT WHEN STARTED REMOTELY THE AIR BAD, ABS AND BRAKE LIGHT COME ON! well the orange wire is supposedly for that but it didnt help...any body running into this problem!?...BTW i have read 10 pages of past post on dodge rams and no one has had my problem with the green and orange not having power AT ALL!       any help would be appreciated, im ready to get this thing working right!
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
