4Runner window module wiring help needed
jtree007
Posted: February 29, 2004 at 10:10 PM / IP Logged
I jsut installed (well in the middle of) an alarm for my Runner and the alarm is installed and works fine. I am trying to wire the rear window so that I can use the remote from the security system to move the window. The security system I have as 3 extra channels, 2 are pusled and the other one is a constant( runs as long as I have the button down). I have a DEI 530T window module to control the window but After wiring it I have not been able to get the module to effictly move the window via the remote nor the in cabin switch (is moves in incraments and not consistantly. I am not going in to how I have it wired as I know that it is sorta right, but mostly wrong ( I know the gorund leads, power lead, and option lead works...that is all I am sure of at this point)
Can anyone give me some pointers or better yet what wires I need to use and where I can find them... I really need to get my Runner back together soon.
Thanks,
Parts I have... Prestige APS-410S Alarm system... DEI 530T Window module.. Power everything on a 94 runner...
auex
Platinum - Posts: 5,041
Posted: February 29, 2004 at 11:43 PM / IP Logged
You need to make sure that you have a very good ground for the 530T. Also in the install manual there will be a description on how to adjust the resistance of the unit. There should be some dip switches on the side of the module. Adjust these and you should be working fine.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
jtree007
Posted: March 01, 2004 at 12:19 AM / IP Logged
I am sure my grounding is fine.. but never hurts to check so I'll re check to make sure.... moved the switches and tried all the different settings and nothing worked... I think I am not tapping the correct wires (near the interiror switch.. and I am also having trubble with the relay that I set up to turn the power on on the acc circuit when the remote is used to move the window... I am geting the output from the realay but not sure which of the 2 ingnition wires or both I need to send the power too... I need to recheck all my connections.. but any other suggestions.. or anyone have any experence working with a 4runner's rear window
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
