astra 777 in 1990 honda crxsi
joecrx
Posted: March 01, 2004 at 9:42 PM / IP Logged
im new to this so i got this new alarm system from asianwolf.com and i dont know where to start or how to  or wich wire goes where. \
need help please
crx
profuse007
Gold - Posts: 2,015
Posted: March 01, 2004 at 10:03 PM / IP Logged
lets start w/ the basic for keyless and security
1.power input: 12v pos and neg
|              12V|WHITE/ black        |+ |ign harness, f/b plug       |
2.keyless: unlock and lock wire
need to add door lock motors
3.security: siren and door trigger(s)
|     DOOR TRIGGER|GREEN/ red           |- |either running brd *2       |
*2 Harness running down and forward from dash indicator has door and hatch triggers.
4.parking light flash: the unit may have 2 polarity to choose from, neg or pos. you can manipulate from neg a pos w/ a simple relay setup, or vice versa.
| PARKING LIGHTS +|RED / green           |   |switch harness, f/box       |
check those wire b4 plug and chug and youll be fine.
pretty simple.
if you have remote start w/ this unit, repost the result above then well start w/ RStart.
Houston,TX
joecrx
Posted: March 01, 2004 at 10:22 PM / IP Logged
still confuse  i want to put  an astra 777 in my 1990 crx si 5 speed  two door no power locks
no i dont have remote start wiht this unit
where do the wires from door trigger input go im so lost
crx
Toru
Copper - Posts: 102
Posted: March 01, 2004 at 11:06 PM / IP Logged
1988-91 Honda CRX Alarm Information
Study that chart. Connect each wire from the harness to the wire described in the chart.
For example, the door trigger. You need to connect the green wire on the harness (negative door trigger) to the green wire with a red stripe (GREEN/ red) found in the driver's running board (I think that means the plastic door sill cover - I don't own a CRX so I am not sure).
