Auto door locks
fjames623701
Posted: March 06, 2004 at 10:50 AM / IP Logged
Hello all. I have just purchased a car secuirity system with remote start and keyless entry. I am a mechanic not a installer but I would like to tackle this one on my own. I have a 1990 Silvarado 3/4 ton 2WD. The locks are the 5 wire with a "ground at rest" set up. I have found on this site that I need 2 realys to make it work. However when I wire them up according to the diagram the regular door lock switch works but when I go to use the remote the lock will work then blow the fuse running the alarm. The alarm is the only device on the wire and it is a 20 AMP fuse running from the Bat. It seams to me like After the relay closes there is a very brief ground present. any help would be greatly apreciated. thanks is advance Jim
Dbfordtech
Member - Posts: 28
Posted: March 06, 2004 at 1:09 PM / IP Logged
sounds like you have the switch side and the motor side reversed.
Dbfordtech
Member - Posts: 28
Posted: March 06, 2004 at 1:26 PM / IP Logged
Hi again, I re-read your problem and paid attention this time, please disregard my last post, I dont think its right
draasch
Gold - Posts: 2,172
Posted: March 06, 2004 at 7:09 PM / IP Logged
drop me your e-mail jim...........
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
