1990 gmc truck 3500 2 door
dinothedog
Member - Posts: 9
Posted: March 13, 2004 at 5:01 PM / IP Logged
I NEEDTO KNOW IF THERE IS A FACTORY RELAY FOR THE POWER WINDOWS AND WHERE IT'S LOCATED
draasch
Gold - Posts: 2,172
Posted: March 13, 2004 at 6:09 PM / IP Logged
what are you looking to do????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
dinothedog
Member - Posts: 9
Posted: March 13, 2004 at 6:49 PM / IP Logged
install a clifford alarm! but the alarm about ten years old
draasch
Gold - Posts: 2,172
Posted: March 13, 2004 at 7:50 PM / IP Logged
are you doing window roll up????? or do you ust need the truck info?????
Good Luck
David
Ace Security
813-376-9778
Tampa
dinothedog
Member - Posts: 9
Posted: March 14, 2004 at 9:50 AM / IP Logged
im sorry ,i need to know where the power door lock relay is and i dont see any wires for power door locks in the driver side kick panel or around speaker in the dash
draasch
Gold - Posts: 2,172
Posted: March 14, 2004 at 12:12 PM / IP Logged
there are no relays..........here is the info that you need...
Power Lock L BLUE BELOW DRIVER SPEAKER OR #203
Power Unlock BLACK/ WHITE DRIVER KICK PANEL
#203- See Reversal Rest At Ground Door Lock Diagram.
if you had a DLS, that would take care of the relal wiring. you would just have to wire up the wires in your truck...
http://wiringinstructions.com/203.htm
Good Luck
David
Ace Security
813-376-9778
Tampa
