keyless entry ranger
wepa
Member - Posts: 12
Posted: March 14, 2004 at 1:39 PM / IP Logged
I have a 97 Ranger with factory power locks and power windows. I've seen in this forum that most of you had problems installing the keyless entry feature of your alarms, and had to put a relay to make it work correctly. My question is, will I have this problem on my 97 (all i've seen here are 99+) ????? If so, how do i fix this (diagram is possible), My alarm has only two wires to set up the keyless entry, a blue wire (unlock) and a green one (lock).
btw. the alarm is a omega k9 mundial, if this helps
thanks for the help
bmf1000d
Silver - Posts: 345
Posted: March 14, 2004 at 2:48 PM / IP Logged
PWR DOOR LOCKPNK/YELDRV KICK PANEL
PWR DOOR UNLOCKPNK/LT GRNDRV KICK PANEL (TYPE B)
I would try and see if it works just buy the lock unlock wires if not here is the diagram for your locks
https://www.the12volt.com/doorlocks/page3.asp#3wp
Just change the 87 to ground
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
draasch
Gold - Posts: 2,172
Posted: March 14, 2004 at 2:49 PM / IP Logged
Make:   Ford
Model: Ranger
Year:    1997
This Database Was Last Updated On:    6/9/2003
Index #: 6437
Alarm
Constant 12 volts YELLOW (4) IGNITION SWITCH HARNESS
Ignition 12 volts L GREEN/ PURPLE IGNITION SWITCH HARNESS
Starter RED / L BLUE IGNITION SWITCH HARNESS
Dome Light BLACK/ L BLUE (+) 84 PIN CONNECTOR BEHIND DRIVER DASH
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH (W/O OEM ALARM) *
Power Lock PINK / YELLOW DRIVER KICK #201
Power Unlock PINK/L GREEN PANEL
* With OEM Alarm Parking Lights Are WHITE/ BLACK (+) At Headlight Switch. #201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
wepa
Member - Posts: 12
Posted: March 14, 2004 at 3:03 PM / IP Logged
thanks for the info, another concern that I have is, that I've been told that the alarm goes of after 45 min of activation because the (GEM??)
draasch
Gold - Posts: 2,172
Posted: March 14, 2004 at 3:56 PM / IP Logged
my notes dont list that problem with this truck...
Good Luck
David
Ace Security
813-376-9778
Tampa
serialthrlla
Copper - Posts: 57
Posted: March 15, 2004 at 3:18 AM / IP Logged
some ranger and b4000, the etac changes polairty after 45 minutes and sets off the alarm,   you can diode isolate it, or you can go directly to the domelight to avoid this problem
wepa
Member - Posts: 12
Posted: March 15, 2004 at 6:39 AM / IP Logged
and how do I do this?
thanks
wepa
Member - Posts: 12
Posted: March 15, 2004 at 3:12 PM / IP Logged
anyone? :(
Moderator - Posts: 12,488
Posted: March 15, 2004 at 3:31 PM / IP Logged
Door Trigger False Alarm Isolation Diagrams
wepa
Member - Posts: 12
Posted: March 19, 2004 at 11:30 AM / IP Logged
I have a 97 ranger, I posted a message not long ago, I was told that I needed two relays for the keyless function to work. I tried that right now and it didin't work, the weird thing is that i conected it directly in to the alarm  without the relays and it works. Should I leave it like that or am i doing something wrong?
thanks!!!!!!
btw my power locks are not aftermarket
