commando 5005 starter/alarm
65MustangM1
Posted: March 26, 2004 at 5:57 PM / IP Logged
I have a 1995 f-150 I installed my commando(delta) car starter in and it's not working !!!
I turns the truck on like it is going to start , but it just sit's there. The book says that the led should be flashing when the starter button is pushed , but it not
And the only way I can get the keyless entry to work it to use the panic setting with the remote..
Everting is hooked up except the , Hood pin switch , and shock sensor.
draasch
Gold - Posts: 2,172
Posted: March 26, 2004 at 10:12 PM / IP Logged
will it start with the remote if you place the key in the ign.????
also some units will not start if the hood switch is not hooked up....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
