Disable VW Golf4 transponder?
jaxman
Copper - Posts: 185
Posted: April 02, 2004 at 7:37 AM / IP Logged
Does anybody know how to disable the built in transponder on a VW Golf 4 ? (2001-2002).
Customer lost one key and one it was used for remote start in the DEI 55U module.
Platinum - Posts: 12,488
Posted: April 02, 2004 at 8:54 AM / IP Logged
Only way to disable the VW system is with a spare key through a universal bypass module, then hooking up the ground out when running wire to constant ground and the power wire to ignition. After this you can just use regular cut keys without having to have the transponder key to start the vehicle. Aside from this, the customer will need to go back to VW and get another key ordered with the proper coded key.
jaxman
Copper - Posts: 185
Posted: April 02, 2004 at 10:47 AM / IP Logged
I need to totally disable it or remove it.
Does the system cut for fuel or ignition or what exactly does it cut ? I just want to get rid of the system once and for all.
VW will take a fortune for a new key with the code.
derek123
Copper - Posts: 163
Posted: April 02, 2004 at 11:14 AM / IP Logged
It's more trouble than it's worth, to try and disable it.
You could pop the transponder pick up ring off the barrel, and tape the valid bow to it, stuff it in the dash. now the cars sees the transponder 24/7.
bmf1000d
Silver - Posts: 345
Posted: April 02, 2004 at 2:50 PM / IP Logged
Yeah i would just bypass it permently and not remove it. A new key from VW is 140 bucks here.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
