Negative armed output
bpm687
Member - Posts: 26
Posted: April 12, 2004 at 1:46 AM / IP Logged
Does anyone know what to do with this wire. Its organe coming from the alarm brain and its orange and it says -NEG armed output Starter disable. Now what do I do with it do I just ground it or what?
CutDog504
Silver - Posts: 643
Posted: April 12, 2004 at 1:53 AM / IP Logged
Hook it up to trigger a starter kill relay.
bpm687
Member - Posts: 26
Posted: April 12, 2004 at 1:55 AM / IP Logged
Do I have to can I just use it for my window roll up module?
bpm687
Member - Posts: 26
profuse007
Gold - Posts: 2,015
Posted: April 12, 2004 at 10:11 AM / IP Logged
you would cut the starter wire into two and one side will come from the key and one will come from teh starter.
Houston,TX
CutDog504
Silver - Posts: 643
Posted: April 12, 2004 at 12:47 PM / IP Logged
Also, pin 86 is wrong. It should be 12 volt ignition. You actually can use a constant to wire it up, but in the past I've found that this causes dead batteries. Its much more reliable to wire it to an ignition wire, but make sure its an ignition wire that is hot during engine cranking also, or the relay wont work right.
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
