Adding shock to factory
sierradenali
Posted: April 18, 2004 at 8:53 PM / IP Logged
wish to add shock sensor to factory alarm on 2004 sierra. relay diagrams or thoughts would be great. will the temp. ground of sensor be enough to trigger dome circuit if i tap into that? need sensor on when truck is off and igition shutting relay off is my thoughts. anyone care to throw their 2 cents in?
thanks guys!
wblakes
Copper - Posts: 202
Posted: April 18, 2004 at 10:47 PM / IP Logged
you can get a shock sensor from www.autotechs.com and add it to any trigger wire to set the alarm off.
sierradenali
Posted: April 19, 2004 at 3:42 PM / IP Logged
i have many shock sensors kicking around, can't i use one of them and use some relay configuration to interface it with factory alarm?
draasch
Gold - Posts: 2,172
Posted: April 19, 2004 at 4:14 PM / IP Logged
is there a hood pin switch under the hood????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
sierradenali
Posted: April 19, 2004 at 4:36 PM / IP Logged
no hood pin or light under hood. seems they dont want sierra denali owners to look under hood! i have been out of install business for 7 yrs and dont have collection of relay configs i had made and gathered over the 19 yrs i was installing. i know i can make some sort of latching relay so shock works when truck is off, perhaps another to increase shocks signal to trigger dome, 1st relay disengaged when it gets ignition? its been quite awhile so anyone who has added shock to factory system with databus wiring in vehicle please hook me upAdding shock to factory -- posted image.
thanks,
Dave
sierradenali
Posted: April 19, 2004 at 7:07 PM / IP Logged
btt
JWorm
Platinum - Posts: 2,208
Posted: April 20, 2004 at 12:13 AM / IP Logged
Wire the sensors ground wire (black) to a true ignition wire (pink) in the truck. When the ignition is off it has a strong enough ground for the shock sensor to work.
sierradenali
Posted: April 20, 2004 at 12:46 AM / IP Logged
will the impact from shock need to be boosted to trigger dome thou?
good idea about ign. wire btw i should have thought of that....suxs getting old lmao
