Peugeot 306 1997 alarm wiring diagram req
Nick-a
Posted: May 04, 2004 at 11:58 AM / IP Logged
Many thanks!
Nick
auex
Platinum - Posts: 5,041
Posted: May 04, 2004 at 6:59 PM / IP Logged
Here is what I could find for a 96.
12volts
Starter blue      ignition harness
Ignition yellow      ignition harness " Fuel cut pump is white wire at a double relay module attached to the firewall on the n/side. Module is brown."
Power Lock orange or white    -   ctrl mod behind rear seat Extend to 3 second lock pulse to deadlock
Power Unlock violet or lt brown    -   ctrl mod behind rear seat Extend to 3 second lock pulse to deadlock
Parking Lights+ red & green      at the steering column
Door Trigger grey or yellow    -   loom driver side A pillar
Trunk/Hatch Pin white      at the bootlight
Tachometer brown pin 4      yel conn. top of the dash
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Nick-a
Posted: May 04, 2004 at 7:21 PM / IP Logged
Cheers for that, should make life a bit easier.
Regards,
Nick
Nick-a
Posted: May 13, 2004 at 11:21 AM / IP Logged
Hi,
Can anyone tell me what door locking system it has (to fit a clifford Avang Guard, 5) everythings done apart from the door locks and brake light now!
Regards,
Nick
laren5
Copper - Posts: 57
Posted: May 14, 2004 at 5:51 AM / IP Logged
Type B:  negative
Good luck
Clifford Alarms
Nick-a
Posted: May 21, 2004 at 2:57 PM / IP Logged
Right...done everything now apart from the remote start, it has a problem. If the cars running and i activate remote start, and turn it off, it waits a second or two and restarts the car without the key etc, but wont do it without the key having been in the ignition when its activated. I can start the car using the manual elements of cliffnet too, but the start command itself does nothing. It can read the RPM. battery etc everything! Any ideas on what to try?
Cheers Guys,
Nick
audioconnection
Member - Posts: 45
Posted: May 25, 2004 at 11:01 PM / IP Logged
i believe you have to bypass the safety feature of the clifford. it has this to stop people starting cars with them in gear. and the pug prob doesnt have a parking lock if its an auto.
if you need local help, call PDS in Fenton, Staffs @ 01782-744556
or paul @ source sounds in sheffield
remember...Friends Dont let friends Install, Take it to a pro..
Nick-a
Posted: May 26, 2004 at 10:05 AM / IP Logged
All sorted now :)
Ta,
Nick
