nissan pulsar gti-r wiring diagrams
gti-r
Posted: May 10, 2004 at 2:14 PM / IP Logged
i need to instal a clifford concept 550 alarm in my nissan pulsar gti-r 1992 Import. the problam is i need the diagrams for my car i allready got the ones with the alarm but need the ones for my car can any one help me
p.s. i would be much appreciated as im looking for a very long time and was recomended this site
thanks a lot
omer
jaurora
Silver - Posts: 429
Posted: May 10, 2004 at 2:21 PM / IP Logged
Nissan
Pulsar NX
1991-1993
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
WHITE
IGNITION SWITCH HARNESS
Starter Kill:
BLACK/ WHITE
IGNITION SWITCH HARNESS *
Ignition +12 Volts:
BLACK/ RED
Dome Lights/Superv:
RED / WHITE
(-) PASSENGER PIN SWITCH
OEM Horn:
GREEN / WHITE (-)
STEERING COLUMN HARNESS OR AT RELAY
Power Lock:
LIGHT GREEN/ BLACK
DRIVER DOOR AT SWITCH/CONTROL MOD. **
Power Unlock:
SINGLE WIRE SYSTEM
Trunk Release:
N/A
Alarm Input Wire:
RED / WHITE
Notes:
** See Note #206 - Single Wire Door Lock Diagram.
Nissan
Pulsar NX
1991-1993
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
BLACK/ WHITE
Ignition #1:
BLACK/ RED
Ignition #2:
N/A
Ignition #3:
N/A
Accessory:
WHITE/ BLUE
IGNITION SWITCH HARNESS (HEAT-A/C)
Brake Light:
RED / GREEN (+)
SWITCH ON BRACKET ABOVE BRAKE PEDAL
Tach Signal:
BLUE/BLACK - DASH TACH
OR ENG CONTROL MOD OR GRN/YEL AT COIL
Parking Lights:
RED / BLUE
(+) AT LIGHT SWITCH
Headlights:
BLACK/ RED (DRIVER) (+)
RED / GREEN (PASS.) HIGH - AT LIGHT SW.
OEM Alarm Disarm:
N/A
OEM Alarm Arm:
N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* This Vehicle Is Equipped With Two Start Wires. Both Must Be Powered In Order For Vehicle To Start When Engine Is
Hope this helps
MECP certified (If it really means anything)
Jeremy
gti-r
Posted: May 11, 2004 at 5:37 AM / IP Logged
hi the car which the diagram is for is not the one for me as the one im loking for is a gti-r 3 door 4wheel drive  turbo
if u need more help with the car visit this site and it should help to identifi the car www.gtiroc.com
thanks
jaurora
Silver - Posts: 429
Posted: May 11, 2004 at 7:02 AM / IP Logged
The wiring should be the same. pop the cover under the wheel and double check.
Jeremy
jaurora
Silver - Posts: 429
Posted: May 11, 2004 at 7:03 AM / IP Logged
If not sorry i cant help you, are going to have to navigate your way thru with a volt meter.
Jeremy
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
