97 Mitsubishi Eclipse Factory Alarm
baker2311
Posted: May 21, 2004 at 2:40 PM / IP Logged
Does anyone know how to disable the factory alarm on a 97 Eclipse?
Brian
baker2311
Posted: May 21, 2004 at 3:06 PM / IP Logged
I should add that the alarm is on my daughters car and has never worked. Now it comes on as soon as you open the door and won't shut off. No button on the key fob will silence it and after it shuts itself off, the car won't start.
Thanks again,
Brian
defective
Silver - Posts: 642
Posted: May 21, 2004 at 3:55 PM / IP Logged
if the alarm never worked, why did youaccept that.,..... did you buy new?
kgerry
Platinum - Posts: 3,455
Posted: May 21, 2004 at 3:56 PM / IP Logged
permanently ground the RED / green at the ECU near the PKP
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
baker2311
Posted: May 21, 2004 at 4:09 PM / IP Logged
No, she bought it used from the Mitsubishi dealer. We didn't know it had an alarm other than the panic button.
I'm really ignorant about new electrical systems, so I don't know what or where about the ECU and the PKP.
Thanks,
Brian
baker2311
Posted: May 21, 2004 at 6:16 PM / IP Logged
Do you disable the panic alarm the same way you would the car alarm? The key fob has a panic button on it, and I think this is actually the problem. Somehow, it's malfunctioning.
jaxon23
Member - Posts: 25
Posted: May 21, 2004 at 7:15 PM / IP Logged
ECU and the PKP is the computer that is behind the passenger kick panel
baker2311
Posted: May 21, 2004 at 11:51 PM / IP Logged
Thanks Jaxon23, I'llgive it a shot tomorrow morning.
anumeric
Member - Posts: 20
Posted: May 23, 2004 at 11:05 PM / IP Logged
hey try pulling out the fuse for the security...if that doesn't work...there is a kick panel on the driver side...you should find a GREEN / WHITE wire...ground it...to shut the alarm up...try putting the key in the driver's side door and turn it to the right...your key fob might not be programmed right...let me know if you want directions on how to do that...i have a 95 eclipse
Platinum - Posts: 12,488
Posted: May 24, 2004 at 12:04 PM / IP Logged
First off, do you know if it's a OEM security or a aftermarket security ? Are you sure that the system was an OEM one ? With my experience with used car salesman, they don't know much about the accessories when it comes to vehicles, they only know how to sell a vehicle. Does the OEM remote FOB have a Mitsubishi insignia on it ?
