DEI 6500esp factory disarm
boosted-fc3s
Member - Posts: 8
Posted: May 23, 2004 at 8:50 PM / IP Logged
I have a customer with a 1988 mazda rx7 w/ the factory alarm.  He insists on keeping the factory alarm functional.  Is there an output on the 6500 that will pulse the factory disarm?  The brain says theres two, but one only pulses w/ remote start commands, and the other according to dei is status/factory rearm?  Thanks.
profuse007
Gold - Posts: 2,015
Posted: May 23, 2004 at 9:30 PM / IP Logged
use the disarm wire to disarm when remote start. thats all you need, when you remotely unlock it should disarm, too.
Houston,TX
boosted-fc3s
Member - Posts: 8
Posted: May 24, 2004 at 2:25 PM / IP Logged
Worked like a charm.  Thanks.
Steve Michaluk
Posted: June 12, 2004 at 2:43 PM / IP Logged
I am trying to locate the factory alarm brain in my 1991 RX-7 convertible.
I am installing keyless entry, and have already installed actuator in
driver's door and run lead wires into car.  I would like to connect to
contant 12v, ground, alarm set, and alarm unset.  Can you please advice
which wire is constant 12v.
Thanks,
Steve
