1999 Dodge Dakota door trigger
cwillis
Posted: May 25, 2004 at 10:58 PM / IP Logged
I have been having problems finding the passenger door trigger on an ext. cab dakota.  I found the driver side trigger which was BLACK/ purple.  I tried using the yellow wire that controls interior illumination, but it is delayed when doors close so it wouldn't work.  Any suggestions?
dag2471
Posted: July 12, 2004 at 3:43 AM / IP Logged
You can catch them in each door.  The triggers are built in to each door lock motor/latch mechanism.
Should be - Driver Door - BLACK/ Lt Blue, Pass Door - Tan/Red
Remember to diode isolate and test before wiring them up.  This is the way I have my '00 Dakota wired, the '99 should be the same.
Saturday, September 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
