02 Civic parking lights
advanced529
Member - Posts: 16
Posted: June 06, 2004 at 11:12 PM / IP Logged
I hooked my white wire for the parking light output on the 791 to a RED / black wire on the back side of the fuse box,,, to be more exact it is the RED / black wire that is in the top middle harness(in the bottom right corner from looking from the back of the fuse box),, I did notice that there was several RED / black wires that had the same activation with the parking light output... It is working fine but I was wondering if I used the correct wire and location...P.s. I did test the wire and it was not the dimmer wire as the voltage remained the same..
Thanks    J
Teamrf
Gold - Posts: 1,031
Posted: June 06, 2004 at 11:31 PM / IP Logged
Test that wire with a DMM.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
advanced529
Member - Posts: 16
Posted: June 07, 2004 at 12:02 AM / IP Logged
I did... I am a hvac tech and only use the highest quality meters.. All the RED / black wires in that harness had 12.5 volts with the parking light switch on and did not vary at all with the dimmer control... As I said,, the parking lights are working perfectly with the alarm.,, but I just wanted to see if this was a good location for the hookup or if there is another prefered place...
Thanks for the reply... J           Also I did van conversions and alarm installations over 10yrs ago and just have not done them in a long time..     If there is another preferable location please let me know...
JWorm
Platinum - Posts: 2,208
Posted: June 07, 2004 at 10:48 AM / IP Logged
If it works, don't worry about it.
