94 Civic oil light wire?
connectorman
Posted: June 10, 2004 at 11:24 AM / IP Logged
Can anyone tell me which wire, (color and location),  I should look for on my 94 Civic that produces +12V from the oil sensor when the engine has been successfully started.  I am installing a PD-175 remote start/alarm system
cul8r
deviousjoker
Copper - Posts: 102
Posted: June 10, 2004 at 11:44 AM / IP Logged
why do need an oil light wire?
First Class MECP Installer
connectorman
Posted: June 10, 2004 at 12:05 PM / IP Logged
According to the manual this +12V signal is used to tell the remote start function that the car is running.  That way it won't try to restart the car.
cul8r
greedy111
Member - Posts: 24
Posted: June 10, 2004 at 1:10 PM / IP Logged
dont they usually use the tach wire, which is blue, to signal that the car is running?
auex
Platinum - Posts: 5,041
Posted: June 10, 2004 at 1:34 PM / IP Logged
It depends on brand as to what is used to tell if the vehicle is running.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
jaurora
Silver - Posts: 429
Posted: June 11, 2004 at 3:18 PM / IP Logged
Yea but an oil sensor wire? For me thats a first.
MECP certified (If it really means anything)
Jeremy
profuse007
Gold - Posts: 2,015
Posted: June 11, 2004 at 4:19 PM / IP Logged
its depend on certain brand and types company creates out there like AUEX mentioned.
if it sense the oil pressure being at a right pressure then thats when the RS discontinue.
Houston,TX
Ashez
Member - Posts: 26
Posted: June 11, 2004 at 7:52 PM / IP Logged
Let me guess, is it a Thor alarm?
