nissan altima 2000
leondrewsmith
Posted: June 20, 2004 at 10:20 PM / IP Logged
i need to know how to bypass the factory keyless entry so i can install a hornet 725 sys
thanks
ElementalSnakeX
Javelin3o4
Copper - Posts: 239
Posted: June 20, 2004 at 10:48 PM / IP Logged
Lock = Gray
Unlock = Purple
Polarity = Negative
Location = Smart Entrance Control Unit, under dash to the right of the steering column, black or blue in color.
auex
Platinum - Posts: 5,041
Posted: June 20, 2004 at 11:18 PM / IP Logged
You don't bypass the keyless entry, you just don't use the remotes.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
tyger25
Member - Posts: 8
Posted: June 20, 2004 at 11:20 PM / IP Logged
Yep, no need to bypass.
