Disable factory alarm
lenster40
Member - Posts: 10
Posted: July 11, 2004 at 9:39 PM / IP Logged
I have a 2000 Tahoe, does anyone know how to disable the factory alarm? I grounded the LT Green wire on the BCM at the purple connector and it still functional, any ideas???
Lenster
lenster
swamprat323
Gold - Posts: 1,335
Posted: July 11, 2004 at 10:39 PM / IP Logged
POWER LOCK|pink *2             |+ |door lock relays *5        |
|     POWER UNLOCK|pink/green *2       |+ |door lock relays *5        |
|       LOCK MOTOR|blue               |   |door lock relays *5        |
|     UNLOCK MOTOR|blue/red            |   |keyless entry module *3     |
|    DISARM DEFEAT|blue/red            |   |door lock relays *5
*2 Also located at the keyless entry module, if equipped.
*3 The keyless entry module is located above the gas pedal.    *5 The power door lock relays are to the right of the brake pedal.
lenster40
Member - Posts: 10
Posted: July 11, 2004 at 11:10 PM / IP Logged
What do I do with the Disarm/Defeat wire (Blue/Red)?  The door locks are connected and working fine.
lenster
auex
Platinum - Posts: 5,041
Posted: July 12, 2004 at 12:37 AM / IP Logged
Hold on there turbo, none of the wires swamprat gave you will help in your situation. Why do you need to do this?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
lenster40
Member - Posts: 10
Posted: July 12, 2004 at 6:38 AM / IP Logged
Auex,
I am installing a remote start on this vehicle.
lenster
swamprat323
Gold - Posts: 1,335
Posted: July 12, 2004 at 2:52 PM / IP Logged
Conect your disarm form the alarm to the disarm defeat in the car.
kgerry
Platinum - Posts: 3,455
Posted: July 12, 2004 at 3:37 PM / IP Logged
did you permanently ground this wire or did you properly hook it up to the alarm disarm wire of your RS unit?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
lenster40
Member - Posts: 10
Posted: July 12, 2004 at 4:18 PM / IP Logged
Kgerry,
I grounded the LT green wire and it still is functional.
lenster
kgerry
Posted: July 13, 2004 at 1:59 PM / IP Logged
did you try to pulse ground on this wire?
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
