Removing the dash on a 1993 Ford Ranger
kmerenda
Posted: July 13, 2004 at 1:24 PM / IP Logged
Hi everyone
I have a 1993 Ford Ranger that was recently broken into, so I have been inspired to install an alarm.  I have some wiring knowledge, but I have never removed the dash before, and I want to be able to do it without damaging anything.  Can someone please post step-by-step instructions on removing the dash in a 1993 Ford Ranger?  Also, if you know another site that may have that info, please let me know.  Thanks!
-Kenneth Merenda
kgerry
Platinum - Posts: 3,455
Posted: July 13, 2004 at 1:56 PM / IP Logged
why would you need to remove the dash to install an alarm??
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
kmerenda
Posted: July 13, 2004 at 2:37 PM / IP Logged
"why would you need to remove the dash to install an alarm??
___________________________________________
Kevin
Classic Car Audio"
I found that there was an old black widow alarm already installed in the truck (along with aftermarket power locks) by the previous owner.  After tracing the wires as much as possible, I have found that some of them (LED in particular) run under the dash in places where I cannot reach them.  I'm also having problems identifying which wires are the door triggers and which are the door locks, so any tips on that would be useful as well.
-Kenneth Merenda
kgerry
Posted: July 14, 2004 at 1:25 PM / IP Logged
if memory serves me correctly in that vehicle you remove the dash screw from the top of the dash bezel...then the small trim panels that cover the bottom of the dash around the cig lighter snap off, and you unscrew the bottom dash screw there.....    it's been a while since i've had to work on a unit that old....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
spokman
Copper - Posts: 75
Posted: July 14, 2004 at 7:34 PM / IP Logged
Why not just pull the stereo, and intrument cluster trim and other trim. You probably will be able to see most of the wires.
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
