Matrix 2.5x Hood/Trunk/Tilt Sensor
djpc80
Member - Posts: 9
Posted: July 25, 2004 at 8:40 PM / IP Logged
hi, if anyones familiar with the 2.5x by clifford i have a question about installing a hood/tilt sensor and trunk pin/switch. How can each of them be isolated to go off per zone. For instance in the manual it says the blue wire for trunk/hood pin,instant trigger/zone 1. How would the alarm system be wired to know when the hood goes off and vise versa, and what would you connect the tilt sensor to trigger a diferent zone icon or something to know if thats going off too? Thanks for the help in advance.
raydawg357
Silver - Posts: 769
Posted: July 27, 2004 at 8:01 AM / IP Logged
You will have to diode isolate each of the different zones so they don't trigger each other.
Do it right the first time
Big Dog
Gold - Posts: 1,265
Posted: July 27, 2004 at 9:50 AM / IP Logged
Connect the hood switch to the small gray input and the trunk switch to the blue on the main connector. Program the transmitter to see these as two different zones as explained in the owner's manual ( RTFM Matrix 2.5x Hood/Trunk/Tilt Sensor -- posted image. )
Prepare your future. It wasn't the lack of stones that killed the stone age.
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
