555G Won't Learn
solson440
Posted: July 28, 2004 at 7:43 AM / IP Logged
I just installed a Remote Starter in a 2003 Bonneville, and I cannot get the DEI 555G to function. The LED flashes for a second, but remote startwill not function without key in ignition. I hav etried to ground blue wire seperate from Remote Starter per https://www.the12volt.com/installbay/forum_posts.asp?tid=25690&KW=555G, to no avail. Has anyone else seen this? Can anyone else help?
Thank you,
Scott
kgerry
Platinum - Posts: 3,455
Posted: July 28, 2004 at 10:24 AM / IP Logged
i've had a couple that were finnicky... have you just tried a 555U? should work fine.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
solson440
Posted: July 28, 2004 at 10:41 AM / IP Logged
I was hoping to avoid that; I dislike "hiding a key." No real reason, will probably end up going that way, though.
Thanks.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
