2002 Dodge Durango Wireing Chart
CarNut
Member - Posts: 22
Posted: September 15, 2002 at 12:43 PM / IP Logged
The diagram chart listed for the 2000 Durango on this site is not correct for the 02 Durango.  I would like to know if anyone has the correct wiring chart (for Alarm/Remote Start with Doors and Windows etc.. Installation) for the 2002 Durango...?
I contacted WireMagic, but apparently they do not have a "one time, DIY," program........
Can anyone help?
CarNut
securinu
Silver - Posts: 772
Posted: September 15, 2002 at 1:04 PM / IP Logged
give me a fax # and i will fax a wiremagic printout. i dont have a scanner so i cant email it.
CarNut
Member - Posts: 22
Posted: September 15, 2002 at 4:28 PM / IP Logged
410-255-5206
Thanks A Million!
CarNut
Platinum - Posts: 12,488
Posted: September 15, 2002 at 4:40 PM / IP Logged
If you have not received it yet here you go :
|              12V|pnk/blk & RED / lt blu|+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|blue                |+  |ignition harness            |
|  SECOND IGNITION|GREEN/ red    (18 ga)|+  |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness            |
| SECOND ACCESSORY|green               |+  |ignition harness            |
|       POWER LOCK|WHITE/ green         |*1 |conn. 2, pin 10 @ CTM *2    |
|     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|ORANGE / black        |   |conn. 2, pin 4 @ CTM *2     |
|     UNLOCK MOTOR|blue                |   |conn. 2, pin 6 @ CTM *2     |
|    DISARM DEFEAT|pink/black          |   |conn. 2, pin 5 @ CTM *2     |
| PARKING LIGHTS +|BLACK / YELLOW        |   |headlight switch            |
| PARKING LIGHTS -|RED / yellow          |   |conn. 1, pin 4 @ CTM *2     |
|       HEADLIGHTS|lt. GREEN/ orange    |-  |headlight switch            |
|     DOOR TRIGGER|*3                  |-  |CTM *2                      |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tan/black           |-  |conn. 2, pin 7 @ CTM *2     |
|  FCTRY ALARM ARM|lt. GREEN/ orange    |*4 |conn. 2, pin 14 @ CTM *2    |
|FCTRY ALRM DISARM|same wire           |   |                            |
|       TACHOMETER|*5                  |   |ignition coil               |
|      SPEED SENSE|WHITE/ orange or blue|   |conn. 2, pin 27 @ PCM *6    |
|       BRAKE WIRE|WHITE/ tan           |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |-  |steering column or CTM *2   |
|           WIPERS|purple(L), RED / gry(H|+  |steering column             |
|  LF WINDOW UP/DN|lt. blue - white    |A  |driver window switch        |
|  RF WINDOW UP/DN|brn/wht - pur/wht   |A  |driver kick panel           |
|  LR WINDOW UP/DN|blu/wht - RED / blk   |A  |driver kick panel           |
|  RR WINDOW UP/DN|gry/blk - grn/wht   |A  |driver kick panel           |
|        RADIO 12V|pink                |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|RED / white           |+  |radio                       |
| RADIO ILLUMINATE|white               |+  |radio                       |
|       LF SPEAKER|lt grn/pu-lt grn/grn|   |radio                       |
|       RF SPEAKER|lt blu/pu-lt blu/blk|   |radio                       |
|       LR SPEAKER|wht/red - wht/blk   |   |radio                       |
|       RR SPEAKER|tan/pur - tan/blk   |   |radio                       |
Notes:
NOTE:  Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U.  *1 Lock is negative trigger thru a 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.  *2 The Central Timer Module is in the driver kick panel.  *3 The driver door trigger is tan in connector 2, pin 15. The passenger door trigger (and rears) is tan/red in connector 2, pin 13. Use both and diode isolate each. See directfax document #1076 for wiring information.  *4 Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger thru a 1565 ohm resistor. MUST use relays. This wire will also lock the doors, and it will unlock with a double pulse.  *5 On the 5.9L models use BLACK/ gray at the ignition coil. The 4.7L models have an ignition coil for each cylinder, use the wires that is NOT GREEN/ orange at one of the coils.  *6 The Powertrain Control Module is on the passenger fender.
CarNut
Member - Posts: 22
Posted: September 15, 2002 at 5:54 PM / IP Logged
You guys are the BEST!!!
Thanks A Million!!
CarNut
Gentleman
Copper - Posts: 71
Posted: September 16, 2002 at 9:54 AM / IP Logged
I did this same install and am having problems with the door triggers, I used the tan and the tan/red, diode isolated them and what is happening is approx 5 minutes after setting the alarm the alarm goes off, I verified my wiring, tested the diodes I am using 1N4001, if I disconnect the door trigger the alarm does not go off, so I know the problem is related to the doors, need help.
securinu
Silver - Posts: 772
Posted: September 16, 2002 at 2:55 PM / IP Logged
goto the yellow wire in the middle plug bottom right of connector of the ctm in the drivers kickpanel this should clear up your problem . it is the domelight wire depending on your alarm you might get a 2nd chirp saying doors are open but this is due to the domelight fading out slowly. good luck
CarNut
Member - Posts: 22
Posted: September 16, 2002 at 3:47 PM / IP Logged
I'm studying the alarm Information (CS2015FM) and see that they are suggesting the use of relays for this setup.. I can’t figure out why? Can some explain the need for relays in a single wire, Negative trigger, system when the alarm will send the negative signal on its own…?
CarNut
Posted: September 16, 2002 at 4:32 PM / IP Logged
You need relays for this sytems because you want to isolate the lock and unlock signals that have the resistors in line so that they do not interfere with each other's function. If you use just one wire then you won't be ablr to lock nor unlock the doors because the resistor value will be cumulative of the two resistors you installed in the wires.
Posted: September 16, 2002 at 5:15 PM / IP Logged
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
