RSX 3.5 remote questions
lilboi
Copper - Posts: 126
Posted: August 17, 2004 at 11:40 PM / IP Logged
I noticed that sometimes, when i lock my car, the lcd display will show Shock sensor 1, several seconds (3-5) after i lock it. What does this mean.
kkeeni
Member - Posts: 20
Posted: August 17, 2004 at 11:54 PM / IP Logged
try to wait a couple of seconds after you shut your door, then arm it. its probably still detects the shock sensor from you shuting the door and triggers sensor 1.
lilboi
Copper - Posts: 126
Posted: August 18, 2004 at 10:31 PM / IP Logged
any one have this problem? I'm not sure if that's the reason. Maybe i'm wrong, i keep thinking that i'm bypassing it.
kkeeni
Member - Posts: 20
Posted: August 19, 2004 at 1:19 PM / IP Logged
yes i have the same alarm system and mine does the same thing when you arm it right after you shut the door , and some of our customers call with the same problem, it worked for them..
kenmci
Copper - Posts: 161
Posted: August 19, 2004 at 1:26 PM / IP Logged
what happens is when you arm the alarm, the alarm checks all of the sensors, doors etc.  It then bypasses any zones that are being triggered so that the alarm will arm.  If you left the door open it would do the same thing only it would show the door icon instead of sensor 1.  There is nothing wrong with the alarm it is simply showing you that the shock sensor was going off when you armed the car, so the shock sensor was bypassed, just hit lock again and it will turn the shock sensor back on.
Frys24
Posted: August 19, 2004 at 2:36 PM / IP Logged
I have the same thing happen to me with my personal remote. its a crimestoper. after disarming then rearm it shows my shock sensor warning. then i just press arm again and it stops. i think its normal for most 2way pagers.
Fry's Electronics store #24 Concord, Ca.
lilboi
Copper - Posts: 126
Posted: August 19, 2004 at 4:15 PM / IP Logged
Cool. Thanks. I have my sensitivty set on really high. I don't mind for false alarms.
