alarm works without ground?
dlee337
Member - Posts: 9
Posted: August 29, 2004 at 6:01 PM / IP Logged
i am installing a 690XV in my 90 Integra.  as i tested everything last night, i noticed that the alarm was working when there was no ground applied to the system.  there is a single ground wire running accross the dash for the system that has the hood mercury switch and siren on it only.  it is not connected to ground.  the battery backup is hooked to the power of the alarm, but the ground is not attached to anything yet.  the ground for the alarm is not attached to anything either. when i apply power to the alarm, it works with no apparent ground.  the only thing i can think of is somehow it is being grounded through the sensors.  the siren works normally.  the mercury switch triggers the alarm when the hood is open.
any ideas why i have ground when there should be none?
auex
Platinum - Posts: 5,041
Posted: August 29, 2004 at 7:31 PM / IP Logged
This is normal. The alarm will try to ground through some of the wires such as ignition or lights. The alarm will not work properly most of the time when it is trying to ground this way.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
JWorm
Platinum - Posts: 2,208
Posted: August 29, 2004 at 11:12 PM / IP Logged
Try using the alarm with the key turned on. It probably won't function.
dlee337
Member - Posts: 9
Posted: August 30, 2004 at 11:55 AM / IP Logged
when the alarm is armed and i try to start the car, it works normally.  the siren sounds and the starter won't engage.  i get the "IGN" signal on the remote.  it seems to work just fine.  theonly thing is the ground wire is laying on the floor.
i plan on connecting the ground wires anyway.  just wanted to make sure i wasn't going crazy or anything.
Teamrf
Gold - Posts: 1,031
Posted: August 30, 2004 at 4:45 PM / IP Logged
Usually the alarm will try to ground through the siren. It will sound very low and funny.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
dlee337
Member - Posts: 9
Posted: August 30, 2004 at 5:03 PM / IP Logged
when i plugged the fuse in at the battery, i got a real low, muffled double chirp.  when i test the alarm, the siren sounds full blast, as my wife can attest to.
everything seems to work normally and the car still works, so i am going to run with it.
auex
Posted: August 30, 2004 at 6:03 PM / IP Logged
You need to ground the alarm, period.
sroth140
Silver - Posts: 513
Posted: August 31, 2004 at 10:01 AM / IP Logged
ground the alarm or it could damage whatever its grounding through.  just because you are being stupid about it and not using a chasis ground, i hope it takes out your BCM or ECU, whatever your vehicles have thats costs the most.  it'd be funny to damage a $1000 part over a ring terminal and a screw, ass.
MECP certified installer
dlee337
Member - Posts: 9
Posted: August 31, 2004 at 10:43 AM / IP Logged
maybe you should learn how to read, sh*thead.  i am well aware of the need to ground the system.
heavilymedicate
Silver - Posts: 328
Posted: August 31, 2004 at 11:33 AM / IP Logged
pppppffttt!  No need to get nasty,  just ground the damn thing and kill this thread.
