Viper Alarm LED Activation Question
jmr964
Copper - Posts: 70
Posted: September 05, 2004 at 10:06 PM / IP Logged
Wondering if someone can tell me if on a Viper (791XV in particular) brain if it sends steady power and pulsating ground to the LED to activate it or if it sends pulsating power and steady ground to light it?
tbirdman74
Copper - Posts: 164
Posted: September 06, 2004 at 1:34 AM / IP Logged
If I'm not mistaken, most use a pulsing ground, but I would just cut the wires and test them with a multimeter to be sure.
If it don't fit, Force it.
If it breaks, You needed a new one anyway!
jmr964
Copper - Posts: 70
Posted: September 06, 2004 at 4:10 AM / IP Logged
Yes I think I will be testing the wires just to be sure.  I was hoping it would be pulsating ground outputs.  I have a 04 Dodge Dakota without the factory security system but it still has the secuirty light in the dash.  It too is an led that lights up the word security in the instrument cluster.  All it needs is to be grounded and I found the wire for that so I will just be hooking it up to the led port on the Viper rather than using the LED supplied.
Jason
extreme1
Silver - Posts: 1,070
Posted: September 08, 2004 at 12:57 PM / IP Logged
Jay, just hook up the blue wire from the LED output.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
