1996 Mustang GT Power Door Lock Problem
cyprisfx1983
Posted: September 19, 2004 at 4:10 PM / IP Logged
HEy guys,
I have a 1996 Mustang GT and I installed the alarm except for the power locks.
   The wiring diagrams say that I have a "3 wire positive" system in the car. Only problem is that my alarm (Omega K9 Classic) uses a negative output on the door locks.
   I tried using the double relay diagram that I saw here and all I do is blow the fuse on the alarms power supply, which tells me that I'm throwing current in the wrong direction. Do I need to use diodes anywhere? Or is some of my information wrong!? I could really use the help.
THanks.
hagmanti
Silver - Posts: 304
Posted: September 19, 2004 at 6:03 PM / IP Logged
Disclaimer-- I don't know the '96 Mustangs at all. Only Mustang I've ever worked on was a '90 (which had five-wire door locks).
According to the Vehicle Information Database here, a '95-'97 Mustang has negative door locks, which are the easiest in the world to hook up. Try taking a fuse holder w/ a small amp fuse in it, and connect the pink / YELLOW wire to ground. If the doors lock, hook that wire to your alarms negative lock wire. Same w/ the pink/green wire and unlocking. (Both wires are in the driver's kick, according to the above link.)
FWIW, if you're using the 3 wire positive diagram here, then you shouldn't be blowing fuses on the alarm's power supply (no matter what the door lock wiring really is)-- you might want to check which legs of your relay are hooked up where.
Me
draasch
Gold - Posts: 2,172
Posted: September 19, 2004 at 6:38 PM / IP Logged
send me your address and i will send you a DLS with two relays...it will plug right into the red plug on the alarm...........
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
another-kelly
Silver - Posts: 618
Posted: September 20, 2004 at 9:16 AM / IP Logged
another disclaimer!!!!!!!!!!!
Power Lock pink / YELLOW    either kick panel   1996 Mustang GT Power Door Lock Problem -- posted image.
Power Unlock pink/green    either kick panel   1996 Mustang GT Power Door Lock Problem -- posted image.
FORD, MUSTANG, 1996, Power Lock
Non-keyless versions are 5-wire and the keyless versions are negative pulse.
draasch
Gold - Posts: 2,172
Posted: September 20, 2004 at 9:36 AM / IP Logged
Power Lock PINK / YELLOW 12 PIN BLACK CONNECTOR ** #203
Power Unlock PINK/L GREEN HIGH IN DRIVER KICK PANEL #201
** Without OEM Keyless Entry See Note #203. With OEM Keyless Entry See Note #201. #203- See Reversal Rest At Ground Door Lock Diagram. #201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
