trunk release 97 sebring convertible
petesneeze
Member - Posts: 14
Posted: September 30, 2004 at 4:00 PM / IP Logged
HELP !!!!!
I am trying to hook up my phoenix pd-175 trunk release function.
Problem 1: My trunk release won't work at all, even with the button in the console! There are 2 wires on it, gray and brown w/blue. The brown w/blue reads 12 volts all the time. The gray reads 12v when the button is depressed, and 4.83v otherwise. But the trunk doesn't open.
Problem 2: the wire from the main control unit is green and says " trunk release, positive output".The info. I got online says there should be a lt. GREEN/ black wire at the release switch (see above)...would this be the button in the console, or the lock mechanism in the trunk? Also, do I need to wire in a relay with this?
I got the alarm and keyless entry all working, but this trunk has got me stumped! Any help greatly appreciated!
pete
draasch
Gold - Posts: 2,172
Posted: September 30, 2004 at 6:42 PM / IP Logged
Trunk Release L GREEN/ BLACK (+) AT TRUNK RELEASE SWITCH #231
most alarm outputs are -ve....if yours is, then you will need a relay........run a wire to the trunk and test it if need be............if the switch is not working, then it sounds like you have a bad spot in the wire somewhere..............
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
mo12v
Posted: September 30, 2004 at 9:49 PM / IP Logged
U might want to check Trunk Motor,  I have replaced a couple of those because of weak & burnt solinoids (Mopar knows they R bad)
MO
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
