Factory alarm problem
2xavier2
Posted: September 28, 2002 at 4:36 PM / IP Logged
new problem- need help
Car: 1995 acura legend coupe w factory alarm
Alarm System:3300 alarm remote starter
Everything works fine doors lock/unlock w remote, remote starter works w remote, but sometimes the cars factory alarm will not disarm when doors are unlocked or remote starter is used w remote.
2xavier2
djfearny2
Silver - Posts: 810
Posted: September 28, 2002 at 4:42 PM / IP Logged
make sure you are connected to right factory wire and use this relay setup to make it work.
http://members.tripod.com/~onsite/DISARM_FACTORY_alarms.gif
Jon
Installer/Help Technician
---coral springs florida---
Platinum - Posts: 12,488
Posted: September 29, 2002 at 10:00 AM / IP Logged
The Legend uses the UNLOCK circuit to also disarm the OEM alarm system. Make sure that the RS unit isn't programmed to auto lock or auto arm after the remote starter has engaged.
