Civic and Prelude
LudeBoi
Copper - Posts: 81
Posted: September 28, 2002 at 11:35 PM / IP Logged
I am a new proud member, just passed by and whoa.. this site rocks, has ALOT of info, well anyway any one know the wire colors for the windows on a 95 Civic an a 98 Prelude? thanks
Sound Pressure
Silver - Posts: 711
Posted: September 29, 2002 at 12:00 AM / IP Logged
95 honda civic= windows up LF-RED / blue, RF-blue / YELLOW                     windows down=LF-RED / yellow, RF-blue/green
98 honda prelude=
Windows UpLF=RED / Blue, RF=Blue / YELLOW in Door only
Windows DownLF=RED / White, RF=Blue
Sound Pressure
LudeBoi
Copper - Posts: 81
Posted: September 29, 2002 at 5:28 PM / IP Logged
thanks,i installed the window modulator today and it doesnt work!!...grr...pissing me off, i made sure all the wires were correct, i was thinkin b/c my alarm aux output only puts out 300ma and the window modulator is 500ma? if not wats the problem? thanks in advance
Platinum - Posts: 12,488
Posted: September 30, 2002 at 5:22 AM / IP Logged
Are you using the proper trigger wires for the module ? Sometimes the modules have a trigger and an AUX wire to other devices ( this is a output not input ).
LudeBoi
Copper - Posts: 81
Posted: September 30, 2002 at 8:06 AM / IP Logged
Thanks for replying,
Im not quite sure what your talking about, but the module has 8 wires:
2 for each window
1ground
112volt
1 500ma ACTIVATION?
1 pink accessory wire?
I have the Prestige aps-25kb alarm, am I supposed to hook up the activation wire from the module to the blue aux wire of the alarm? or is a relay needed? thanks alot
Mobile Ins
Member - Posts: 6
Posted: September 30, 2002 at 9:10 AM / IP Logged
Hi all..i'm new to this site but i'm trying my best ..i'm form Canada,Ontario and working as Master/Installer
make sure you wires not wrong and after cuting driver door window up wire you need to remember which side going to motor and switch if it's not right window won't work..also from APS-25 you have to connect Orange wire but if you using this wire for starter disable it won't  work on window module and you need diodes to aviod ground coming from starter kill realy.
the module you using it's just for one function either window down or up.. Pink wire don't need to connect..it's out put for some accessory
Mobile Installer
LudeBoi
Copper - Posts: 81
Posted: September 30, 2002 at 4:45 PM / IP Logged
yeah im trying to make both windows go up when i push the little green button (aux 2), yes i am using the orange wire for starter disable, so im supposed to use the blue wire and simply connect it to the activation wire of the module rite?
John
Posted: September 30, 2002 at 9:31 PM / IP Logged
What is your activation wire timed out for ( BLUE ) ? The activation wire will only roll down the window for as long as there is current in the trigger wire. If you hook up the starter disable ( to close the windows upon arming the system ) then attach the starter disable wire to the activation wire on the module. This wire will stay active for as long as the car is armed, but don't worry because the window modules have an automatic current spike regulator that monitors current spikes and shuts off power when the windows are fully closed.
LudeBoi
Copper - Posts: 81
Posted: October 01, 2002 at 2:29 PM / IP Logged
thanks, i hope this works!!
John
LudeBoi
Copper - Posts: 81
Posted: October 01, 2002 at 4:06 PM / IP Logged
it works.. but it makes the windows go up instantly after i take out my key out of the ignition..but i found the problem of the whole thing! it was a faulty aux button on the remote!, but now i came across another problem, i connected the activation wire to the aux output and it works, but i'll have to press the aux button a few times, because it goes up and stop, so i have to keep pushing the aux button to get it to completely rolled up?!?
